137Views3Replies
Making a Inverter with 12V Solar panel.
Hello There,
Some One Tell me how can i Power Up my Desktop PC with 12Volt Solar Panel that is rated Max Current Of 10Amps, so i want to make a DIY Inverter with i can Ran my Desktop PC , The load of PC is Approx. 500 Watts. I know how to Convert DC to AC but the Problem is Power(LOAD).
How can i Make it to work With Max power of 500 watts?
Help me Plz
Regards,
AB
4 years ago
Hey, Thanks for your Response,
#Downunder35m, In the Cloudy Day the Solar panel gives 12-14 Volt,
And Normally, it gives 16-17 Volt(checked with Multimeter)
In the post above the Spec's i mentioned is Written On Solar Panel(on the Badge)
But i am Sure Thats not Accurate, Since the Voltage is 16-17, And it has also Written 150Watt means The Current is Greater then Mentioned.
#rickharris
Dear The Output of solar is too Greater then max rating of Mobile Phone, Since All chargers(mostly i see) is rated 2A, 5Volt
And the solar panel has 16-17 Volt, i dont want my Mobile Phone Melts :)
4 years ago
use the output of the solar to charge batteries
4 years ago
12V X 10A = 120W at the best of times.
You would be lucky to get 80 on a cloudy day.
The inverter would have some losses too.
So it really takes only basic math to see it will never work.
