72Views3Replies
Author Options:
Marking photosensitive film Answered
Can I use scratch pads and permanent marker pens to place hole pads and make traces on a photosensitive film? Can I use UV lamps?
gmoon
gmoon
3 years ago
You can use UV lamps for the photoresist on the treated or precoated pcb, if you go that route. I had an old sun lamp that worked well.
Photosensitive film isn't a necessity. I used to make the films with a laser printer, on laser transparency film (usually sandwiched two layers together for more opacity).
Even that's not necessary -- you can actually place adhesive pads and traces directly on an uncoated PCB. For one-offs, of course.
rickharris
rickharris
3 years ago
You can mark the PCB with a resist pen and do it all by hand.
You can coat the surface in some kind of resist and scratch through it.
I don't think there is any point in using UV film unless you used it as designed.
steveastrouk
steveastrouk
3 years ago
Usually the film is stuck to the PCB, and exposed to UV light through a stencil.
