2733Views10Replies
Mathematical formulae and wind instrument help.?
Is there a mathematical formula for the arrangement of hole on a flute or better a recorder.
In addition has anyone every tried to make a saxophone mouthpiece ?
I am interested in trying to make a DIY version of a Xaphoon http://www.youtube.com/watch?v=j3Wnx2VYZq8
Best Answer 10 years ago
For a tube closed at one end (by a mouthpiece), the frequency (f) of a note produced is
f = v/2L where v = speed of sound in air (340m/s), and L is the length of the tube. For you, that is the distance between the mouthpiece and the first un-covered hole.
Rearranging to solve for L, you're looking at L = v/2f
For instance...
Google reveals that "middle C" is 523.28Hz
L = 340/(2x523.28) = 0.324873872m
With rounding, the length of a tube that gives a middle C = 0.325m = 32.5cm = 12.8 inches.
If the first hole uncovered by your finger is 32.5cm from the top, you will get a middle C.
Answer 10 years ago
Doesn't the diameter of the tube have an effect?
Answer 10 years ago
As long as the tube is significantly longer than wide, no.
Answer 10 years ago
The Wikipedia article agrees and disagrees:
http://en.wikipedia.org/wiki/Acoustic_resonance#Open
Answer 10 years ago
Oh, hang on...
I quoted maths above assuming that the tube resonated as a closed tube.
However, the maths for a closed tube traditionally places the sound generator at the open end. These Xaphoons have the sound source at the closed end.
Damn. I've over-thought myself.
Answer 10 years ago
They do indeed - it is a Saxaphone reed /mouth piece.
Is the measurement made from the tube end or from the sound source? in my case there may be some slight difference
The U-Tube video I linked to shows the original "inventor" making them by hand from bamboo BUT he is a musician and sax player and I am not but I would like to try to make one from PVC pipe.
My reason for wanting the maths is I have a profile of a Xaphoon and They say it is 12.5 inches long, I have made an "accurate" scale drawing f the picture and want to check the measurements I get from it.
Even flutes and recorders, in fact all musical wind instruments AFAIK, produce the sound at the closed end.
Thanks for all your efforts guys - any more input is welcome before I start dismantling the house plumbing!
Answer 10 years ago
I thought it works only for a kind of flute where you move a stick in and out of it, then it's a closed tube of a variable length and it is easy to calculate the length of a standing wave inside (even I can do it). But what happens if the flute is open at the end and in lots of little holes except one?
1) Air flow though the open holes is obviously significant, so we can't consider it a tube...
2) I have no idea of how to calculate a standing wave inside such a thing, but I can't believe it continues to be the same formula.
PS I think that a tube closed at one end is a thing where the wave meets a solid wall at the end.
10 years ago
This link might help? It has a link to an online calculator too :)
10 years ago
will follow your link Thanks
10 years ago
searching for 'woodwind recorder math' in google got me a pdf about how to make them...
and a dude says 'the math is difficult, but I wrote software to calculate it"...
http://www.logarithmic.net/pfh/design
I have not tested this software nor can I presume it's remotely safe.
