129Views3Replies
Author Options:
May I be advised on powering cheap lasers from this device? Answered
I've got a "6V" SLA connected to it's original charger.
It's currently driving a motor with a mirror glued to it, I want to add a couple of cheap laser modules to the same power supply.
>SLA  charges at over 7V
>No load voltage is less than 6V
>When running the motor the voltage across the terminals is less than 5V
I do have a couple of UA79M12C -ve voltage regulators, and think I should use one.
The cheap lasers are built to run from 3 button-cells (~4.5V)
Advice appreciated
L
steveastrouk
steveastrouk
Best Answer 8 years ago
Get yourself an LM317 and program the output voltage to 4.5V. Job done as far as I can see./
Steve
lemonie
lemonie
Answer 8 years ago
OK, I might have something like that, somewhere... You wouldn't expect the UA79M12C (that are right in front of me) to work in that voltage range then?
L
steveastrouk
steveastrouk
Answer 8 years ago
They're not readily adjustable - PM me if you want a couple dropping in an envelope.
Steve
