103Views6Replies
Author Options:
Metal hallide ballasts - projects using? Answered
I had to buy 2 salt water aquarium ballasts because they where dirt cheap, solid and shiny.
I have no use for 2 shiny MH ballasts.
Any suggestions for projects? Practical, informative or destructive? Not necessarily in that order ....
Kiteman
2 years ago
Don't ballasts do interesting things to voltages? Would they drive a small Jacob's Ladder?
bmiller91Kiteman
Reply 2 years ago
I know an HID ballast will drive a ladder but I didn't get a spark even across a very small gap. Maybe I just need to "Prime" to get it started but I was leery of shorting it out.
Kitemanbmiller91
Reply 2 years ago
Not an actual clue myself - maybe another member with more high-voltage experience can help?
-max-Kiteman
Reply 2 years ago
Add them in series to a MOT to power them is common. I'm thinking if it's not too hard, to add additional turns of wire and make a transformer, but that's kinda boring. Using them as power factor correction for capacitive loads like really crappy LED lights might be cool, but the inductance is probably too high for that... IDK.
bmiller91-max-
Reply 2 years ago
So you're suggesting to use output from ballast as power for MOT? MOT output is then super high voltage but low current? Not healthy but less deadly than powering MOT with 120/240v AC?
-max-bmiller91
Reply 2 years ago
I dont have any actual experience with MOTs, but yes, basically. MOTs are cheaply designed and undersized for their rating and are only meant to be run for breif periods while force cooled. Adding a ballast in series with them is required to run continously. The magnetic shunts limit the output current already.
