737Views3Replies
Author Options:
Best starter microcontroller for project? Answered
Yes, i have already visited https://www.instructables.com/id/How-to-choose-a-MicroController/, and it did not help me much.
My last question was a bit ambitious, so I decided to restart with some more info.
The project requires: (8) LED; (9)Toggle Switches; (2) Variable Resistors; [1] Relay (20 total)
I'm new to this whole thing so I don't know which controller to choose. I did a bit of research, and I think the arduino will do what I need it to. But I don't know if the ATmega168 can be used without the board. (I need about 5 units). Will the arduino suit my needs? Or is there something better out there?
steveastrouk
steveastrouk
Best Answer 11 years ago
Now take that spec apart, you need enough outputs to drive 28 devices, enough inputs to receive 9 and you have two analogue inputs as well.
This is a very good intro to rolling your own uC project
http://itp.nyu.edu/physcomp/Tutorials/ArduinoBreadboard#toc6
There are loads of different processors that will do what you want. Used bare-bones, an Atmega168 won't hack it. You'll have to expand its I/O somehow. You can expand the I/O with a single smart chip, driven over SPI, or you can roll your own with serial to parallel converter chips. I happen to like the Maxim MAX 7301 for doing that, but if you haven't had much experience, writing a driver would be pretty daunting.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3371/t/al
Steve
ericsnapple
ericsnapple
Answer 11 years ago
Hi Steve, I have only 1 concern: 28 devices? If you don't mind, could you tell me where those 8 extra devices came from? (I'm sure I'm overlooking something) Last time I checked the arduino specs, it had 20 pins.
steveastrouk
steveastrouk
Answer 11 years ago
I mis read the last item as 20 relays ! Sorry ! Yes, it'll fit in an Atmega Steve
