345Views4Replies
Author Options:
Microwave transformer electromagnet? Answered
Hi so I was bored and decided to make an electromagnet out of a microwave transformer by taking the secondary off and keeping the primary. I hooked it up to some 9v batteries and stuff but it wasn't that strong so I researched it a bit and found out you can hook it up to the transformer input voltage (which was 240v AC) so I did but when I turned it on it made this very loud buzzing noise and I thought I saw what looked like flame in the socket. I turned it off imediately and unplugged everything. Whatever the magnet did must of been strong because it broke itself apart slightly. I tested the sockets with a multimeter and they still say 240v but I just want to make sure I didn't do anything bad to it. Also did anything actually go wrong or was this all meant to happen?
steveastrouk
steveastrouk
4 years ago
A.) Electromagnets work on DC.
B.) When they work on DC they will pull current = Volts/resistance.
C.) On AC, they will pull nearly the same sort of current as B.) when you have destroyed the rest of the magnetic circuit.
You are very lucky to have not started a fire.
jlandreth1
jlandreth1
Answer 4 years ago
So is everything still meant to work? For example I can still hook it up to 9v batteries and stuff and it does the exact same thing that it did before I plugged it into AC. Will the plug be okay?
steveastrouk
steveastrouk
Answer 4 years ago
You'll kill 9V batteries in very short order.
Yes, it will be OK, provided you didn't get any smoke out of the coil.
I am not sure about the socket and plug. Flame makes me worry about carbon damage, which is a problem.
jlandreth1
jlandreth1
Answer 4 years ago
Thanks I might do a bit of testing for the socket just to be sure also there wasn't any smoke so I'm pretty sure the coils fine. And yeah I did realise it was taking a lot of power from the 9v and was making sure I didn't use them too much or they get too hot but I'll be more careful now. Thanks
