232Views4Replies
Author Options:
Minimum Venturi Diameter?? Answered
Hi,
I'm trying to make a venturi in an application.
I've run some simulations with success, but as soon as I simulate it with the right scale (4mm diameter inlet of pressure) the simulation doesn't appear to show any venturi effect and the vacuum doesn't work.
Does the venturi effect have any minimum diameter to make it possilbe?
If not, how can I generate vacuum using a 4mm inner diameter tube?
Thanks,
Yair.
steveastrouk
steveastrouk
6 years ago
As far as I know, no, there is no lower limit, what you are seeing is probably the result of the granularity of the simulation. What matters is the ratio of inlet to outlet diameters.
yairtzur
yairtzur
Answer 6 years ago
So theoretically it should be working just fine as long as I keep the same ratio between all parts of the venturi?
steveastrouk
steveastrouk
Answer 6 years ago
Yes, but if you make it small, you'll inevitably need more pressure to feed it with enough flow rate.
