187Views3Replies
Author Options:
Modding a laptop to be solar? Answered
I saw an instructable for a solar-charged ds lite (the solar panels soldered right to the top) and I was wondering if it would be possible on a larger scale for a laptop. Would this be terribly tricky to do? Would it hurt the screen? Any information at all would be awesome, many thanks.
bwrussellcanucksgirl
Answer 6 years ago
+1. I think the ratio of the ratios between the ds and laptops lid areas, and battery capacity is such that you may end up with more of a trickle charger unless you build extra panels that fold out.
Using made up numbers:
Lid area (ds:laptop): 1:5
battery capacity: 1:10
This means one unit of solar cells properly charges one unit of battery and so in this example you would have half as many cells as needed.
I could be totally wrong but laptops are very power hungry so it stands to reason this would be the case.
canucksgirlbwrussell
Answer 6 years ago
I remember seeing some prototype solar laptops over the past few years that utilized a fold out in the lid to increase the solar panel area. And you are correct, I use a laptop all the time, and they are definitely power hungry machines (depending on the resources you are consuming of course). The only feasible way that I see something like this working is for someone who is truly on the go and outside more often than inside. For me, I spend a lot of time on my laptop inside and during the day and it charges throughout the night, so a solar laptop wouldn't really be of any benefit to me. Plus you'd still have to use a battery (and simply charge that) versus relying on the solar panels for running the machine as you'd have a heck of a time positioning the lid to the sun while you operated it. :-)
