4745Views3Replies
Author Options:
Modify LED fade in/out circuit? Answered
I am building this circuit
https://www.instructables.com/file/F4J70N0FRAAPMYY/
Here is the breadboard of it. This works, so if the schematic is different, use this instead.
https://www.instructables.com/file/FEYVJ1FFRJKN3PR/
I want to modify it so that is uses a 5v power source. What resistor should I change and how many ohms shuld the new one be?
I also want to add a potentiometer so I can change the fade in/out speed. What resitor should I put it in place of?
Thanks for the help.
frollard
frollard
11 years ago
Great question!
I'm surprised that your circuit works - its missing some components for a 555 timer to work...
Perhaps the missing components make it run slowly enough to make the eyes actually fade...
So... the 500 ohm resistor is to get enough current for 4 leds. To run at 5 volts instead of 9 you need a smaller resistor there.
http://home.cogeco.ca/~rpaisley4/LM555.html has everything you could need to know about the chip...
the spec sheet shows the 555 should run on anything from 4.5 to 16 volts.
Try applying 5 volts with a smaller current limiting resistor.
lokivoid
lokivoid
Answer 11 years ago
"I'm surprised that your circuit works - its missing some components for a 555 timer to work..." I dont see anything missing, If your refuring to a resistor the transistor is acting as one in the terms of timing control for the astable circuit.
frollard
frollard
Answer 11 years ago
Indeed...the wiring just totally threw me off.
