103Views7Replies
Author Options:
Motion Control Switch- triggering Elwire project- need HELP Answered
I have a motion controlled light switch that activates a glowing aqua elwire arch. It lights up when anyone approaches the hallway. Problem is that the switch is allowing 3 volts through even when there is no motion. This measly 3v is enough to power the inverter and light the elwire. How can I add 3v of resistance to block that leakage?
Fotmasta
Fotmasta
13 years ago
I called Leviton, maker of the motion switch. 2-3v leak is normal for that. They recommend using their other motion switch which uses a relay. Unfortunately it's a $56 switch.
LasVegas
LasVegas
Reply 13 years ago
Or you could add a relay to your current switch. A relay won't trigger with the leak and would open the contact when not activated. The only concern is that the current out of the switch be strong enough to both power the relay and the light.
trialex
trialex
13 years ago
To add some resistance, you could say add... A RESISTOR!! Alternatively you could use a diode. Silicon diodes typically have a 0.6V drop, so you could keep adding them in series until you drop below the forward voltage for the EL wire
fungus amungus
fungus amungus
Reply 13 years ago
Or an LED so you know it's on.
Fotmasta
Fotmasta
Reply 13 years ago
A 3v or 4v LED in parallel?
trialex
trialex
Reply 13 years ago
Nice one...
LasVegas
LasVegas
13 years ago
I'd suggest you try to repair the switch rather than jury-rig it. The most common cause for a device like this to fail are failing filter capacitors. A failing capacitor would cause low or fluctuating power to the entire circuit. Look for one or two large can capacitors in the power supply section of the device. Replace them with exactly the same capacitance (marked MFD or uf), the voltage should at the very least match, but I would select one rated for a higher voltage to avoid future failures. Make sure that the capacitors are installed with the same polarity as the old.
