92Views4Replies
Author Options:
Mousebot Help...Plz Answered
I have been working on the mousebot on and off for a few weeks now. Yes...weeks. Completely new to everything about it. I have everything together and after the same problem last build I am stuck. 1 motor is getting 3.3 volts. 1 motor is getting 7.78 volts. Resulting in a spinning bot. I removed the eyes (desoldered the sensor from eye stems) so ,if I am thinking correctly here, both motors should get the same voltage. Wires are bare, not touching. Again...this is the second build with same exact result, so I am doubting I soldered the same exact connection badly. I also replaced the relay and LM386 with new ones for second build. Any ideas??
Kiteman
Kiteman
12 years ago
Sorry, I don't know, but if you add macro shots of what you have done so far, maybe others will be able to help.
m3lt
m3lt
Reply 12 years ago
It will be embarrassing...But maybe that is what is needed. The main problem, I guess, is what/where/how does the power get from the IC to the motors. There must be something about the relay I don't understand. 1 + wire from IC controls both motors? This can't be right, so I'm guessing the relay does the switching of voltage. Is that true? If so I need to check more closely my relay wiring/connections.
Kiteman
Kiteman
Reply 12 years ago
Dude, I can't really help, you haven't even told us which mousebot you're trying to do.
m3lt
m3lt
Reply 12 years ago
I didnt know there was more than one...I apologize. Mousey the junkbot. MAKE magazine style. Volume 2 to be exact. With a reverse switch.
