218Views6Replies
Author Options:
Multiple RFM69HCW with the same Node ID? Answered
I wan wondering if it was possible to have multiple RFM69HCW (https://www.adafruit.com/product/3070) nodes with the same node ID on the same channel. My project I am doing involves a large amount of receivers and 1 transmitter in which I need all the nodes to receive the same message at the same time. Is this possible? I know the ACK wouldn't work as intended as from what I understand, but I am okay with that if this is so.
bigjohn412
bigjohn412
4 years ago
I figured out how to accomplish this. simply send the message to "node id" 255. This will broadcast a message to nodes 1-254.
steveastrouk
steveastrouk
4 years ago
No, each module must have a unique node ID, BUT the PACKET you send doesn't NEED an address, and your receiver code can ignore it.
bigjohn412
bigjohn412
Answer 4 years ago
So it is possible to send out a general mass message to multiple receivers from one transmitter you're saying? Because that's all I'm attempting to achieve lol
steveastrouk
steveastrouk
Answer 4 years ago
Yes. At the higher level, your receiver code is responsible for determining if a given packet is destined for it. At a hardware level, node IDs are compulsory.
bigjohn412
bigjohn412
Answer 4 years ago
Okay awesome, Thanks a lot! I have one more question if you care to help! How would I go about sending a mass message out to the multiple receivers? Like I know in the RFM69 library, the send function requires a node ID number as far as I know. I've been working with these boards for about a month now so I am still kinda new to the library and the RFM69HCW boards. Thanks!
steveastrouk
steveastrouk
Answer 4 years ago
Take a look at the detailed chip datasheet. You'll probably need to look at the Arduino driver code too.
I glanced over the chip datasheet to find what you needed. The rest is up to you....
