2737Views10Replies
Author Options:
My bike wheels wont turn! Answered
 Well, I was messing about on my bike with my friend, I went to peddle, heard a huge snap and now it wont peddle. Well, it will but the wheels wont turn when I peddle. Can anyone help?
NachoMahma
NachoMahma
Best Answer 10 years ago
.  Sounds to me like the gearset has broken loose from the wheel hub. You probably snapped the bolts holding them together.
.  If it is a coaster, you probably broke a pawl.
Re-design
Re-design
Answer 10 years ago
I assumed by "wheels won't turn" that meant locked.  But I'd bet your're right about the pawl.
NachoMahma
NachoMahma
Answer 10 years ago
.  Who knows at this point? Since "ramp" is in the keywords, a broken axle/bearing/&c is still a definite possibility.
Millawi Legend
Millawi Legend
Answer 10 years ago
 What i meant by ramp is that i went up a rap a couple of times that when I went to peddle the peddles were turning but the wheel wasn't.
dragonsniper
dragonsniper
10 years ago
why dont you post a picture of your bike so we can see the problem?
Re-design
Re-design
10 years ago
Did you check the brake bracket?  Are they rubbing?
If that's not it then I would suspect a broken axle or a bearing problem then.
There's not much else that would cause your problem.
coolpizzadude
coolpizzadude
10 years ago
You might have screwed the rear sprocket.
lemonie
lemonie
10 years ago
Have you checked that the chain is still in the right place, and not off a sprocket and jammed?
L
Millawi Legend
Millawi Legend
Answer 10 years ago
Yes, the back sprocket turns, but wheels just dont.
lemonie
lemonie
Answer 10 years ago
See anything broken?
If the rear sprocket turns but the wheel doesn't something bust there. Does it have hub-gears?
L
