481Views10Replies
Author Options:
My joule thief is not very bright? Answered
My joule thief is not very bright? I've changed the windings, transistor and the resistor; and it is still pretty dim. Help please Parts: 2 different size toroids: Large and Small 3 Transistors: 2n2222, 2n3904, 2n5830 2 Resistors: 1k, 2.2ohm blue led white led with a heatsink Also I used a 20awg and 36awg to make the toroids
steveastrouk
Best Answer 10 years ago
I suspect you simply haven't got the energy available from the battery driving the Joule thief, nor have you got the current handling you need - close to 300mA. A Joule thief is a very neat thing, but it "cannae brek' the law's o' physics" to coin a phrase.....
steveastroukdaemonral
Answer 10 years ago
Try feeding it with a good low voltage supply. A 'C' or 'D' cell should do it. Try using a thicker wire on your windings. The transistor can handle up to 800mA, but the gain will fall off as your collector current increases. Try and Change LED. Use a red one. Make some measurements with an oscilloscope. Steve
steveastrouk
10 years ago
You SAID its very bright, how can very bright be very dim ?
daemonralsteveastrouk
Answer 10 years ago
I'm sorry I meant to type dim I must have blanked out
Joe Martin
10 years ago
Have you tried a different battery?
lemonie
10 years ago
Pictures, parts, specifications and a circuit diagram would really help here (otherwise people are just guessing). L
