1326Views6Replies
My kitchen peninsula has a soffit that is packed with insulation - - what's the best way to remove both?
Apparently the soffit is part of the ceiling - - i.e., open on top - - - that's why it's filled with blow-in insulation. I just want to remodel our kitchen - - which includes removing the peninsula and the problem soffit/insulation. Maybe the biggest problem would be to replace the insulation when I'm done.
Best Answer 12 years ago
Given the limited information to answer this question I hope this helps: Step 1) Isolate your working area by draping plastic around the room you wish to work in. Step 2) (As NachoMahma mentions) If you are able to gain access to the attic, remove the insulation first. Step 3) Bust open the soffit and remove. Step 4) Complete demo / installation Step 5) Make sure to use proper vapour barrier and insulation when reinstalling your new ceiling board. Good luck!
Answer 12 years ago
Thanks, Mikeasaurus - - isolating the area is a good idea. I've had zero experience with insulation & vapour barriers - - - guess it's time to learn.
12 years ago
http://forum.doityourself.com/architecture/258064-interior-soffit.html
Worth an extra post.
"I am sorry Dave, I can not do that."
12 years ago
. If you have access to the attic, it will probably be much less messy if you go up there and remove the insulation before removing the soffit. Replace the insulation when done with the project.
Answer 12 years ago
There's currently no access to the attic - - the kitchen is isolated by a vaulted ceiling. Thanks for your response.
Answer 12 years ago
. Ah. Then check mikeasaurus' answer.
