That's probably a bad idea. The DS runs on about 5V and you would probably fry the board. instead take an unused usb cable, cut off the other end, and use those wires.
If it's not the battery, it may be the bottom touchscreen. Check to see if its cracked because this happened to me. If the touch screen cracks and the liquid crystals seep out, the DS will refuse to turn on.
12 years ago
connect a small car incandescent lamp (12 V 3-5 W) to +- of the battery. if it lights up a bit then battery is ok
Answer 11 years ago
Answer 12 years ago
will it work when plugged in? will it work when plugged in WITHOUT battery installed?
12 years ago
Charge it, the light should turn on when connected.
12 years ago
