117Views12Replies
Mystery board game or puzzle?
Hi everyone,
Can anybody identify this mystery board game or puzzle? I was given it with no instructions, its in a nice hard wood case, it has 15 blue marbles and 15 white ones. There is 30 holes in total 9 on the top and 21 on the bottom.
Thanks.
4 years ago
I think this is 2 games. the top is TIC TAC TOE and the bottom some kind of solitare
Answer 4 years ago
+1
Whether or not the bottom is some kind solitare, you could make up a game for that format.
Answer 4 years ago
It could be, Im also starting to think its a factory dud as there is space for four more holes if it were laid out a bit better.
Answer 4 years ago
All the tic tac toe games Ive seen have lines drawn on them, but it could be...
4 years ago
It is home made ask the maker.
Answer 4 years ago
No it was bought from a shop, but they lost the instructions.
Answer 4 years ago
You bought that at a shop.
Non of the holes line up, you can clearly see that in the picks.
None of the holes are the same size, you can clearly see that in the picks.
They used a miter joint in stead of a finger joint, screaming amateur box maker.
Cheep hasps and hinges mounted poorly.
No box corners.
I would say the top game is Tick Tack Toe and the bottom game is a marble version of Pegs.
No game is 30 spaces and 30 pieces there is no where to move.
Answer 4 years ago
It was probably made by some poor 8 year old kid in Thailand, give him a break.... ;-)
Answer 4 years ago
I think I have the bottom game, there are a number of peg games.
War
You set up the board, ten blue on one side ten white on the other center hole empty.
You can only move if you can jump a marble.
You loose your marble if it is jumped by your opponent.
The game is over when nether player can move.
The winner has the most marbles on the board.
The wood is nice it's a shame it isn't made better.
There was an IQ peg game that was all the rage years ago. The board was a triangle with one hole empty you played it by jumping a peg and removing it from the board. Your IQ was higher depending on the number of pegs left on the board.
Answer 4 years ago
Thanks Josehf. Does it have any other name?, I couldn't find any thing on the net about it.
Answer 4 years ago
Yea Battlefield
https://www.siammandalay.com/products/battlefield
I found it in one google peg board games.
Answer 4 years ago
Thanks again Ive seen that game before its also called switch 16 but i dont think they are the same, the "war" game seem a better fit
