86Views6Replies
Author Options:
Need advice on making a proposed rocket I've devised different to the ones seen on here, before I waste materials? Answered
I was thinking of making a rocket and using the fuses in a party popper as the propulsion, I was going to set up 4 gutted poppers with just the fuses on a 600ml/1 or 2 lt bottle and use a string fuse attached to the popper fuses at equal distrance running into a centre fuse/string to light it and get clear.I would use skewers or something to make it launch straight up.I would have the bottom of the popper housing/film cannister against the ground/launch pad.
Has anyone tried this? Would the popper/poppers just simply blow up the thing I put them in and not work? Would I be better of doing the film cannister cannon thing instead of poppers.?
Tags:Rocket
lemonie
lemonie
11 years ago
Poppers don't sound like a good propellant, not 4 anyway. Fireworks or water tend to be a "safer" bet. L
grentes
grentes
Answer 11 years ago
Would doing the whole deodorant spray/perfume inside the cannisters the poppers are in and using the popper as the ignition for the fumes work in stead of the motor?
grentes
grentes
Answer 11 years ago
Have seen that, but there's the whole thing of getting each one to light at the same time, as I said I was going to try a multi motor rocket, even if it doesn't work out and blows up it will be interesting. Don't worry about shrapnel, I'm going to build a fold in half blast shield and use a welding mask eye piece/s in the middle to be able to still view the launch while hiding behind blast shield.
grentes
grentes
Answer 11 years ago
Actually, would a sparkler/match powder based fuse ignite the combustables in the cannisters?
lemonie
lemonie
Answer 11 years ago
Matches can make good propellant & fuse, only trouble is that you need a lot of them for anything above small.
L
