104Views6Replies
Author Options:
Need help... Need to know what type of power supply I need for 54 high power leds? Answered
54 High power leds
6 pcb strips with 9 leds each
3.2v 700ma per led
Wired in series
steveastrouk
8 years ago
These strips usually carry their own resistors in my experience. What are they rated for ? Usually 12V.
rickharris
8 years ago
http://led.linear1.org/led.wiz
Will tell you al lyou need to know and even work out the circuit for you.
ARJOON
8 years ago
connect them with a 180v power supply. don't forget the 3w resistors. better connect them in parallel.
orksecurity
8 years ago
How are the LEDs in each strip wired?
Parallel -- both within the strips and between them -- would seem to make more sense. In that configuration you'd need a 3.2V supply which could provide up to 54*700 ma, or about 38 amps.
Note that this comes out to a bit over 120 watts. Not all of that will come out as light; some of it is going to be heat. You'd better think about how you're cooking this beast if you don't want to cook the LEDs.
orksecurityorksecurity
Answer 8 years ago
Sorry, change "cooking" to "cooling". Though, as I say, if you aren't careful...
7654321
8 years ago
Small gas powered generator?
What are you going to be using it for?
