Need help building an rgb led music sync.?
I see a lot of step by steps showing how to build a simple vu meter but I am looking to do something a little different.
I am currently building a new desk and along the back side of the desk I want to install a row of rgb led's. I would like to set them up so that the led's change color from green to red in increments based on the volume level associated to a certian frequency. so the far left of the desk responds to low frequency and the far right would be high.
I think this would be pretty cool effect but need some help connecting the dots. I am hoping there may be some adruino programing availibe to do the signal proccesing and then for each signal I would just need individual volume meters?
the only other thing missing is where to incorporate the rgb settings.
Best Answer 9 years ago
Do any of the Instructables under "related" do what you want? If not, what don't they do?
If you want more references, websearch "LED color organ".
Answer 9 years ago
it is amazing how much the right search term helps. the color organ is almost exactly what I was looking for. I just need to try to find a design that incorporates rgb led's, instead of single color. using some op amps I should be able to to seperate the l and r audio channels by low, mid and high frequencies.
