75Views4Replies
Need help finding project?
Hi Guys,
I have been searching all over the place (YouTube, Instructables etc.) but I couldn't find my desired project. What I want is a light that is like really bright or long range and CAN BE POWERED BY UPTO 4 AA CELLS. The power is the main problem, I only want to power it with AA cells. So, if anyone could find a project that meets my need I will be really happy.
Thanks in advance.
-Prickly Potato
Best Answer 5 years ago
Your limitation is the amount of time your going to be able to run your light on the 4 x AA battery. Assuming really good http://data.energizer.com/PDFs/E91.pdf
suggests you going to get 2 hours use from then if you draw 1/2 an amp.
0.5 amps at 6 volts is 3 watts. So there you are .
You need a 3 watt LED, a suitable constant current supply (use the search function to find one) and whatever you need as an case. .
Of course you could research more powerful batteries, or even expand your specification to different power sources.
https://www.youtube.com/results?search_query=power...
I am thinking however you so far haven't tried very hard.
Answer 5 years ago
1+
Being able to to ask our good friend Google is always a bonus ;)
5 years ago
If you want to build a flashlight that works on 4 AA batteries and lasts a long time, You probably won't find one...
I find that 18650's are a lot better
5 years ago
Are you looking for Ultrabright LED projects like this.
https://www.instructables.com/id/Extremely-Simple-5...
