103Views8Replies
Author Options:
Need help wiring 10w leds and constant current drivers. Answered
I have a 12v 16amp power supply and i need to hook up 6 10w leds together along with cooling fans/heatsinks and constant current drivers.
Its my understanding that i need 6 constant current drivers. one for each led to prevent overheating.
i can hook up one no problem but how do i connect all 6 together with the 12v 16amp power supply in parallel?
if i was using a resistor it would only have to connect it to the positive side of the power supply in parallel but as u can seen in the pic the cc driver have neg/pos on both sides.
im making an aquarium light.
I have
6 heatsinks and fans 12v
6 10W Constant Current LED Driver DC9-24V to DC8-11V 850mA for 10W High Power LED
6 10w leds
Specification(10w)
Model Type: High Power Integrated Chip lamp Beads
Integrated approach:3 Series 3 Paralleling
Forward Voltage: 9-12V(if use DC 12,Recommended Series a about 1.50 ohm resistor to use)
Forward current: 900mA Luminous Flux:
90-120LM/W Color-rendering index: 60-85 Beam Angle:
120 degrees Working Temperature: -20 centigrade to 60 centigrade
Color Temperature: Warm White: 3000-3200K
Tags:led 10w
steveastrouk
Best Answer 1 year ago
You need NO resistors with these drivers.
Here is my final attempt to explain
monopolymoneysteveastrouk
Answer 1 year ago
excellent
thanks steve
makes sense now with the diagram.
appreciate all your help.
steveastrouk
1 year ago
Just wire them in parallel like this.
steveastroukmonopolymoney
Answer 1 year ago
My diagram shows how you wire the supply wires of the drivers to the power supply. One way of looking at it, is there are 6 pairs of wires.
monopolymoneymonopolymoney
Answer 1 year ago
maybe its not possible. maybe i need to have six sets of wires coming from the power supply.
