45Views0Replies
Author Options:
Need help with a project Answered
Hi, I am making a project with arduino that has to run two nema 17 stepper motors that will turn separate pinion gears for a rack and pinion and a single servo to move and arm up and down. I want to be able to control everything with a wired control pad. If anyone knows an instructable that would help with this could you let me know please. I have not had any luck finding anything. Thank you.
Downunder35m
Downunder35m
1 year ago
There might be things out there going in a similar direction.
Although not exactly like you might think.
For example in several robotic projects you will find bits and pieces to use, like a joystick control to move something.
Similar in 3D printing and milling code.
As a start I could imagine to use a simple milling machine code and to make it work with simple push button controls for all directions and movements.
From there a routine could be added to include the position data, directions and actions from the buttons.
Replacing the buttons with a cable and pad is than quite easy.
