Need help with this MICRO camera ...?
Hello ... I would like to kindly ask anyone, that is good in electronics for help. I add 3 pictures of the SPY PEN and my questions are about the small camera(JH 70-B). I would like to make this camera to make VIDEO via a cable (not to write it on memory) ... but just by a (RCA) cable so I can use any recorder I would like.
I have a few questions, that are bothering my mind and I can't help my self :(
1. would the camera be able to give video signal by it self or does it need some part of the PCB board ??? ... (I mean ... if I would give + and - to some of those pins ... and find one pin, that would give the video signal)
2. If I need the part of the PCB board ... could you show me, where would be the VIDEO signal ??? And where would be +/- ???
In my (totally amateur) opinion, I think, I will need a part of the PCB ... but I don't know, which of all these components are part of the "camera"to give video signal.
Thanks for any advise ... zholy
11 years ago
judging from how many pins it has, it probably is a closed system. if you wanted to do as described, you would need a controller system. the cost would probably not be justifiable when you can get readymade products doing what you want for about $80
11 years ago
You need a device to read the output from the camera and encode it to a video-stream. I'm thinking that this is set up for stills? You'd be better with something like a web-cam I think.
L
