668Views10Replies
Author Options:
Need some urgent help in Hydraulics!! Answered
I want to participate in a Robowar tournament in IIT, India. For the weapon I am planning to use Hydraulic claw just like Razor from Robotwars. Could someone please tell me what are parts needed for the hydraulics?
steveastrouk
steveastrouk
Best Answer 9 years ago
Hydraulics need high pressure pumps, pressure bypass valves, oil reservoirs and double acting hydraulic valves for the ram.
They can be VERY dangerous to play with.
Jayvis Vineet Gonsalves
Answer 9 years ago
steveastrouk could you please give a brief explanation about double acting hydraulic valves for the ram.
steveastrouk
steveastrouk
Answer 9 years ago
Hydraulic cylinders usually use two ports, one to push the rod out, and one to push the rod in, the valve needs to operate in both directions. When the end stops are reached, the pressure bypass in the pump kicks in, and oil flows in the pump/reservoir circuit
Re-design
Re-design
9 years ago
THis is going to be expensive. Google "12 volt hydraulic pump" . THen look for a cylinder, valves. lines and a tank to see what I mean.
Answer 9 years ago
Yup, using hydraulics is expensive, what do you reckon about pneumatic?
Re-design
Re-design
9 years ago
I'll bet it uses an air piston with a valve and storage tank.
iceng
iceng
Answer 9 years ago
+1
onrust
onrust
Answer 9 years ago
Air? Could CO2 be used? The small tanks from a pint ball gun would be sweet.
iceng
iceng
Answer 9 years ago
Or N2
Answer 9 years ago
The Razor uses hydraulics
http://en.wikipedia.org/wiki/Razer_(robot)
Here is a video of it in action
http://www.youtube.com/watch?v=_e4cHWS2758
Could someone please tell me the parts required for this hydraulic system?
