497Views43Replies
Need to identify 2 objects: one works "like" a lock, the other looks LIKE a door knocker....
Pictured are the two items: several pictures of the FIRST item are included since it needs them so show "what" it does and all it's nuances; the second item there is only one picture of it and a notation on the picture.
Can anyone identify them? The "brass" looking first piece seems to work like some sort of lock with a very simple I beam shaped "key" to unlock it. The black item "appears" to be a door knocker "except" it is WAY too light in weight (aluminum or something).
Thank you for any replies....
OH and BTW, can't we add "notes" to the pictures anymore?
5 years ago
A lock and a musical bell clapper.
5 years ago
Goodhart, The query on your second image; A shot in the dark, but, is it possibly a lid prop or hinge of some sort? You know, like you have under the hood of a vehicle to prop up the hood?........ it is quite small, according to your description, so a door knocker seems out of place in that size. IDK. just a guess.
5 years ago
So, I am coming into this WAY late.. but was looking for something else when I saw your trunk lock. Nice piece, goes back to mid 20th century, and you got all that.
The second piece...looks like an anchoring system part. The smaller hole would be wear a line, small rope, would be tied. You would use the "T" to pull that line to another point for anchoring, like a hook. The problem being that it is copper. So it would be used for anything bearing a lot of force.
Just a thought from a sailor engineer.
Reply 5 years ago
www.imaginestics.com
9 years ago
The first image is a Chinese Trunk Lock (see picture). If you go to google images with those words, you'll see a number of similar photos.
Although I couldn't find another exact image, I'm fairly certain that the darker object is cast iron (even being light weight) and its most likely a "bob style" door knocker (versus the ring style), or an old-fashioned door pull. Chances are it was a one-off design, so I would take it to an antiques dealer, to get a sense of its age and origin.
I hope that helps. :)
Reply 9 years ago
The second piece is "so" light weight, I at first thought it was wood, But it is a painted metal....just quite feather weight :-) BTW, that "door knocker" appearing bit is small enough to nearly hide in the palm of my hand without folding it over. It is setting in a 9 inch paper plate back, with room to spare on both edges. Why the part the looks like the knocker part, would have a ringed (hole) end on it is perplexing if that is indeed a knocker.
Reply 9 years ago
A ring style knocker is definitely more common nowadays, but they did have a "bob style" years ago; which makes me think what you have is quite old.
Here's a few examples of other bob style knockers. I would definitely take yours to an antiques dealer to find out for sure. A lot of these things were made as one-off's so you might not find as easy of a match as with the Chinese Trunk Lock.
Reply 9 years ago
The (smaller) hole, as it were, appears to have a purpose: i.e. it's there to hold something. That may just be my perception, but it bothers me that the entire piece is SO very lightweight; it couldn't, if made to hang something on, be made to hold any real weight. Other then the "larger hole" you can see in the picture, there is no other obvious way to attach it TO something (the small hole would serve to "turn the piece sideways, if used to attach it to a flat surface like a door). It is probably the picture that is giving a false impression of what it looks like: it has a "flat black" painted appearance to it. Where I have a note on the picture saying the "hole in the end" makes a "small loop"; that may be misleading too. The "hole" appears to be "squared off", as if to attach it to something or to attach (hang) something from it; in a flush manner; again, that may just be my perception.
Reply 9 years ago
I get what you're saying. Since both items were bought off ebay in a group of misc items, I wonder if this isn't another Chinese item of some kind. Maybe its just an ornamental object, like art, versus having a specific purpose. It's hard to say for sure. Do you have a China Town neighborhood where you live? Maybe its worth asking around if they've ever seen anything like that before (you can always say you got it with a Chinese Trunk Lock). They might be able to figure it out right away or give you some idea on what to search.
Reply 9 years ago
The fellow travelled so it COULD from anywhere....one more bit of info.....I looked at it MUCH closer....the black has shades of green which gives me the idea it MAY have some copper in it.
Reply 9 years ago
I looked around some more, and saw some promising similarities to antique hinges & latches; whether for a door, a cupboard or even a trunk, I think that's the key in identifying this object. I'm not sure how it would have been attached (per your comments), but there are some ornate pieces that look like this. Maybe email the "American Pickers" show from the History Channel, and ask if they have some idea what it is. It couldn't hurt. The worst they'd do is ignore you or say they don't know, BUT, if they know what it is and they want it, they may offer you some $$$.
Reply 9 years ago
I am starting to think it attaches at the smaller (not pictured) loop, and that it is a "pull" of some sort.
Reply 9 years ago
If there's another piece, it may be a fancy old latch for a trunk or box...
This might be an overly-obvious question, but did you email the seller and ask what this is? If they don't know, I'm sure they can at least tell you what part of the world it came from.
Reply 9 years ago
My wife got it in her box lot, but I am not so sure she is THAT interested in knowing what it is....I will inquire though, just in case she wants to ask him.
Here is what the "end" with the small hole looks like >
9 years ago
The last item, maybe ancient Chinese fishing tackle?
Reply 9 years ago
I am at a loss as to "how to search on Google" for something like this. So far, will all the different suggestion from everyone, I've still got pretty much "nothin" :-)
Reply 9 years ago
Tried reverse image search?
Reply 9 years ago
Since I don't see that in Google's line up of "tasks that can be performed" (not even the fully extended list), I assume you mean a program used after downloading? One like TinEye?
Reply 9 years ago
No, Google Images has the same functionality as TinEye (well, I'm sure people would debate all day as to which is better, of course). Go to Google Image Search and you can upload a photo as your search.
Reply 9 years ago
Ok, I found it and tried it.....a cat? really? a bow tie, a nude sculpture from behind and a dresser drawer? What needs to happen is they need MORE images in their index (they don't search the entire WEB for these matches, btw)
Reply 9 years ago
It's not as simple as "index more images," though. (For one thing, you may have noticed that awhile back they changed the way they link to images because they were getting into legal issues directly linking.) I agree that reverse image search is often hit and miss, but it's a neonate technology which has problems that are compounded by operating in an area where the copyrights are a huge pain. And on top of it all you threw a (apparently rare) object at it which it may simply not have any more pictures out there. :D
Reply 9 years ago
Yes, but according to the folks at TinEye, when given more access to more images to index, they will have a greater number of "choices" to offer.
Reply 9 years ago
I had tried both Tineye and Google, and although Google found some "visually similar images"... they weren't anything close to this item. (i.e. one image was a black 'bow tie'). ? o_0 ?
Reply 9 years ago
LOL
Reply 9 years ago
I tried using TinEye, and got: 0 Results
Searched over 2.0907 billion images.
Reply 9 years ago
Tried it with google images?
Reply 9 years ago
when I click on Images...it asks for a description, what am I missing ?
9 years ago
http://urbanite-diary.blogspot.com/2009/02/shanghai-old-street.html
Second image, same locks.
Where did you get those?
Reply 9 years ago
the first 5 pictures are of the same thing, the last picture is the second item....
Reply 9 years ago
I meant, the second picture on the site I linked to :)
Reply 9 years ago
OH ok, yes, I found thank you !
Reply 9 years ago
images.google for "chinese lock" and you'll find similar things.
Reply 9 years ago
Apparently, from what my wife says, the fellow she bought this box lot off of from eBay, travels quite a bit (small jacket patches from Italy, India, etc were included).
Reply 9 years ago
Nice find!
Reply 9 years ago
Thanks, and my wife got them in an eBay lot package of misc items....
Reply 9 years ago
Did she accidentally bid on this instead of the "water torture kit"?
Reply 9 years ago
She doesn't have THAT much patience LOL
9 years ago
The first item is a lock. The real question is what it locks. Possibly it keeps something like a mail-sack shut?
As for the "door knocker" - are there any holes in it, other than the large loop we can see to the right of the image?
Reply 9 years ago
Thanks: & added a note to the picture discribing the hole
Reply 9 years ago
So, now I'm thinking something to do with anchoring boats...
Reply 9 years ago
+1 on the second image.
My first thought was that the crossbar may be there to stop it pulling back through a port leaving whatever attaches to the other end outside.
Is there any chance of a picture from the side?
Reply 9 years ago
It's a Chinese Trunk Lock. (I posted an image... they're identical).
Reply 9 years ago
colorex mentions "old chinese locks" and when I image googled that I got a lot of stuff like it, lots of them fancy like this one:
