100Views1Replies
Author Options:
Need to make a wire between two poles shake at random intervals. Do have a 4mm micro vibrator motor, but nothing else. Answered
11010010110
11010010110
12 years ago
try to get larger motor. connect it so that it can shake the wire or the pole (not spining the wire). play with its speed. at certain speeds it will get into resonance with the reflections coming back from the other end of the wyre and amplify itself if its full size electrical poles and very thick wire try the following. run 2 wires between the poles side by side (not one above the other). connect together at the far end, pulse short pulses of very high current into the wire with welder if its moderate size scale up the 1st one (with high power motor) or scale down the 2nd one
