469Views7Replies
Need to recover access database with superior solution to fix access database errors?
I have a task regarding access database. I and my organization is using access database to maintain my access files in well mannered way. But due to varied reasons access file showing error message
Error 3112: Your access database got corrupted will not be able to show the database.
Due to this error message I will not be able to access my access database. I don't have any idea how to recover access database or how to fix access database errors without affecting my original database????? Is there any relevant solution to repair access database?????
Best Answer 6 years ago
Do you happen to have a backup of your database? If so, the following the instruction:
Restore an entire database
When you restore an entire database, you replace a database file that is damaged, has data problems, or is missing altogether, with a backup of the entire database.
If the database file is missing, copy the backup to the location where the database should be.
IMPORTANT If other databases or programs have links to objects in the database that you are restoring, it is critical that you restore the database to the correct location. If you do not, links to the database objects will not work and will have to be re-created, such as by using the Linked Table Manager.
If the database file is damaged or has data problems, delete the damaged file and then replace the damaged file with the backup.
Or try:
eRepair Access is a powerful Access database recovery solution for damaged *.mdb and *.accdb files created in Access 2000 and above.
For more information: http://access.erepairtools.com/
And the similar question was discussed here: http://www.filerepairforum.com/forum/microsoft/microsoft-aa/access/933-ms-access-database-recovery
4 years ago
Repair Access Database is another
powerful third party software, which allows users to extract complete MS
Access database with its key internal data structure. The software
supports the recovery of MS Access database from both MDB and ACCDB
file. To get more detail about the software, go to:
http://www.repairaccessdatabase.com
4 years ago
When a MS Access database file gets corrupt, you can try one
of following methods to recover data from it:
quickest way to recover data from corrupt mdb or accdb data file.
useful feature accessible from Utilities/Tools menu.
blank Access database and import all the tables and data from corrupt database
to new database using import wizard.
& repair but helpful in minor corruption issues.
download Stellar Phoenix Access Repair software (http://www.stellarinfo.com/access-database-repair.php) and let the software scan your
corrupt file. You will be able to see the preview of corrupt file after
repairing.
4 years ago
Access data file recovery tool helps torepair MDB file and successfully reconstruct
the damaged or corrupted MDB files to provide accessibility to the data stored
in access files and easily restore access database file with quarries, reports,
tables, forms etc. - See more at: https://softcart.wordpress.com/access-database-recovery-software/
5 years ago
It is common problem and lots of users faces such kind of problem. I am also one of them. There are two solutions to resolve this problem.
1. You can try Compact and Repair utility to repair corrupt access database file.
2. Try access recovery tool.
To know more details visit here: http://nalavadebela.wordpress.com/2014/07/15/access-database-repair/
5 years ago
Recently I used Kernel for Access file repair software to fix and repair corrupt access database file. It is is a versatile database recovery program that enables users to restore and repair corrupt or damaged access database file. You can use this great tool. I found this software here: http://www.accessrecoverytool.org
5 years ago
Hi,
Access repair tool
will help you in repairing the several corrupt access database file and restore
all the files objects in new MDB file. It repairs Access file that are not
accessible due to corruption in Access databases, Tables, Queries, Forms, or
Reports.It supports MS Access 2010, 2007, 2003, 2002 & 2000.
See through: http://accessrepairnrecovery.com
5 years ago
New Access database repair tool will help you in repairing the several corrupt access database file and restore all the files objects in new MDB file. Evenly software also restore the records that have been previously deleted from access database.
Go through:- http://www.softmagnat.com/access-database-repair.html
5 years ago
Use Access File Recovery software helps you to recover and repair Access file that are not accessible due to corruption in Access databases, Tables, Queries, Forms, or Reports.It supports MS Access 2010, 2007, 2003, 2002 & 2000.
Go through:- http://www.filesrecoverytool.com/access-file-recovery.html
5 years ago
In this blog http://how-to-repair-access-database.tumblr.com/ the author speaks about four programs to help you recover your data in MS Access, I recommend this post to you.
5 years ago
I agree with the opinion about the backup is the best option, but in some case we don't have a backup, so we need a really solution. In my experience I used AccessFIX of http://www.cimaware.com and is very good, maybe your price is expensive, but the results are fantastic.
5 years ago
Access file recovery program expediently restore inaccessible MS Access file. It restores user data from corrupt Access file To get more details visit here:-
http://www.recoverfilesdownload.com/access-file-recovery.html
6 years ago
Access File Recovery Tool that easily repairs corrupt MS Access (.MDB or .ACCDB) database file and then recover tables, queries, forms, macros, reports, etc. It also restores permanently deleted data from MDB file of MS Access 2013, 2010, 2007, 2003, 2002, 2000 on your latest Windows 8.1 PC & all below Windows version like as Win8, Win7, Vista, 2003 and XP.
So Download:- http://www.recoverydeletedfiles.com/access-file-recovery-tool.html
6 years ago
Do a web search for MS Assess Db repair and you'll find several software tools that can help. If none of them work then your database may be corrupted beyond repair. In which case i hope you have a backup. If not, leasson learned, start making backups.
Answer 6 years ago
+2
