Odd Breadboard Question
Hi All
I am brand new to hobby electronics and would love one day to be able to create the endless amount of cool Instructables but I have ran into a problem on my first attempt at putting theory into practice and would really appreciate any help. I have made two diagrams / images showing the circuit I made I have attached them to this post.
I am using an Arduino Uno as a power source.... I ran a 5v positive from the 5v pin on the Arduino using solid core jumper to the top of the breadboard onto the positive row / rail and a negative / ground jumper to the bottom of the breadboard.
In the middle of the breadboard I placed a 1k ohms resistor bridging the gap / grove/ divide and ran the positive feed through it and on to the anode leg of the LED. The cathode leg of the LED was connected to the negative row / rail completing the circuit.
All works as it should because of the high resistance from the resistor the LED barely lights and is green as it should be. So without using a multimeter I know and can see the resistor is clearly working.
However if I move the resistor so it's still on the same line / row as it was but no longer bridging the gap the LED goes super bright and turns yellow which means that the resistor is no longer working which I can't figure out why because I know there is definitely current flowing through it given the extreme reaction of the LED.
I vaguely remember reading somewhere on these forums that Fritzing is not liked very much so I hope no one minds but to help explain what I mean above I have created two diagrams / pictures using Fritzing.
The images diagrams shows the resistor "bridging" and working and the other shows it not bridging and therefore not working.
So my question would be why given the resistor has current flowing through it does it not work unless it's bridging this middle divide / gap / grove?
It makes me think I am missing something really stupid that everyone should know about breadboards but just seems really odd to me.
Many Thanks
Rab
