98Views4Replies
Author Options:
On and Off Switch? Answered
I have a kiln that I need maintained at a certain temperature for an extended period of time (9 hours). Problem is  the kiln I got doesn't maintain its temp, it just constantly supplies heat until it would kill itself. Making me sit there for 9 hours turning it on and off exactly once a min. Obviously this is a problem... there is a physical on and off switch where maybe I can rig up some timer to hit it for me? Otherwise maybe there is a way to modify the wall outlet to supply power 1 min on, 1 min off? Any suggestions would help, thanks :D
http://www.clay-king.com/images/quickfriec.jpg
clockworkfish
clockworkfish
6 years ago
I am currently looking to figure this out as well, however I do know that what you are looking for is a PID controller. These can be made, and I think that there are ones that plug directly into the wall and into your kiln. Wish I had a bit more of a robust answer for you but that should put you down the right path.
Vyger
Vyger
6 years ago
I would think that one minute intervals would not make a difference at all in temp. Maybe 10 or 15 minutes ---- sounds a little strange as it takes time for things to cycle especially something with a sizable mass like a kiln. Think of it like turning your furnace on and off every minute. It would not even have enough time to run a normal cycle.
You should be able to find a high temperature thermostat that will keep your temp in the correct range.
ReconIII
ReconIII
Answer 6 years ago
It's a very small kiln
steveastrouk
steveastrouk
6 years ago
Get a temperature controller off ebay.
