7514Views5Replies
Author Options:
On/Off/On Toggle switch to 2 separate power sources to power one device? Answered
i have a device the i want to have an on-off-on switch power the device switching from 12AC adaptr to off to powered by 12DC battery. the switch that I have has a 6 terminals
Quick Ace
Quick Ace
1 year ago
cooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooool
LeePrather
LeePrather
1 year ago
Im looking for a on off on switch would allow 2 different power sources that will run 2 separate devices. power supply #1 would always run device #1 and power supply #2 would always run device #2. Does such a switch exist and if so from what source?
FarmerKJS
FarmerKJS
6 years ago
i did this exact thing just last year for this project here.the power source was an internal battery and a external source.I attached a Google image and that's all you have to do. just swap the input for the output and you should be good
seandogue
seandogue
6 years ago
Generally, the way this is done is by using the bypass on a 2.5mm/3.5mm DC power conector to disconnect the "other" power source when the DC power suplly is connected. Otherwise, yes, you an use a DPDT switch for the purpose.
iceng
iceng
6 years ago
That is all you need.
Are you certain it is a toggle switch and not a slide switch, or a rotary switch, or a push switch, or a rocker switch ?
Is the terminal configuration DPDT = Double Pole Double Throw, or one pole five throw = 1P5T, or 3PST = 3Pole Single Throw ?
rickharris
rickharris
6 years ago
I can't see or test your switch BUT most double pole double throw centre off switches will work with this circuit - IF that is what your asking for
The left and right side are separate switches. When you have it in the centre - off
When to the left PSU
when to the Right Battery
