61Views3Replies
Author Options:
Once again, I need Batch Help Answered
Is there a command that can count the times a code "plays/runs" and then do something with that number? such as....
@ECHO OFF
echo.
Echo Hi
Echo.
pause >nul
Echo.
:again
start Blah.txt
goto :again
If goto :again = 5 times goto :end <---- concept Idea
:end
echo.
echo now its opened 5 times
echo.
pause
Now if it went to again 5 times is there a way that i can send it another anchor in the script?
Prof. Pickle
Prof. Pickle
8 years ago
@echo off
set /a num=0
echo.
echo Hi
echo.
pause > nul
echo.
:again
start Blah.txt
set /a num=%num +1
If %num% NEQ 5 goto again
goto end
:end
echo.
echo Now it has opened 5 times
echo.
pause
Tell me if that doesn't work
xACIDITYx
xACIDITYx
12 years ago
You could do a sort of like (now this won't work, b/c I'm not that experienced with batch, but you can use it as inspiration)
set x=0
:again
start blah.txt
if x < 5(
set x=x+1
goto again
) else (
goto end
:end
exit
spiker
spiker
Reply 12 years ago
hmm interesting, thanks for idea, other Ideas are still welcome though
