932Views3Replies
Author Options:
Op Amp Distorion oscillates when on high distortion? Answered
I'm making an op amp distortion pedal, but as I turn up the gain, its starts squealing just when the crunchiness starts sounding good! Is there any way I can stop the oscillation?
8bit
8bit
12 years ago
How does it work?
jeff-o
jeff-o
Answer 11 years ago
I *think* what you're encountering is actually feedback. If you could watch the input on a scope, you'd probably see the waveform sitting on a DC rail (ie. something other than 0V), slowly rising towards the positive power supply voltage. The input resistor pulls it back down.
insomartin
insomartin
12 years ago
i used the 10k trick too, listen if that is a 60hz hum you might need little filtering.
jeff-o
jeff-o
12 years ago
Try putting a 10k resistor from the input of the op amp to ground. That's all I can suggest without seeing the circuit.
