218Views4Replies
Author Options:
Over-Charging Capacitor Answered
What happens if you connect some form of dc power source that supplies 100 volts to a capacitor that is rated for 100 volts, and leave it plugged in for a long period of time. would it eventually "over charge" and explode? would it over heat? would it loose its  ability to store energy?
gmoon
gmoon
4 years ago
All caps have a finite lifespan. Routine cycling them can expand that lifespan.
Leaving them charged (within the specs) shouldn't lessen their expected life. IDK if it would extend it like cycling the charge, though.
merlinj
merlinj
Reply 4 years ago
So if i leave it plugged in, and the voltage i'm charging it with never exceeds the rated voltage, then it will not explode, or break from over charging?
Downunder35m
Downunder35m
Reply 4 years ago
That what is called "rated limit" - you should stay a little bit under it though to increase the lifetime.
merlinj
merlinj
Reply 4 years ago
so as long as you charge your capacitor, with slightly under the rated limit of voltage, you can charge it for days, and it will neither blow up, nor damage it?
