92Views1Replies
Author Options:
PIC18LF4680 microcontroller and usb ttl for usart / serial data Answered
hi everyone.
I want to know if it's possible to connect a ttl device directly to my PIC18LF4680 for serial communication via USART . I can connect the ttl device directly to my Arduino Uno without issues.
The ttl  device has 6 pins
(dtr , rxd , txd , vcc(3.3v or 5v) , cts, gnd) .
I have two different codes snippets below that perform USART communication.
* Version one(I) utilizes the "usart.h" peripheral library.
* Version two(II) uses "TXREG" and "RCREG" for sending and receiving data.
Both versions run well in my virtual environment (Proteus 8 Professional),
but not in the real world environment. Am I missing a step? Do I need a special
library? Or is it not possible with this chip?
VERSION (I)   ------------------------
#include "fuses.h"
#include <p18lf4680.h>
#include <stdio.h>
#include <stdlib.h>
#include <plib/usart.h>
void main(void) {
    TRISB = 0x00;
    OSCCON = 0x76;          // 8mhz (0111 0110)
     LATBbits.LATB4 = 0;
    LATBbits.LATB1 = 0;
    LATBbits.LATB0 = 0;
    unsigned char txt1[] = "Hello World \r\n";
    unsigned char txt2[] = "Enter a number.... \r\n";
    CloseUSART();
    OpenUSART(USART_TX_INT_OFF &
            USART_RX_INT_OFF &
            USART_ASYNCH_MODE &
            USART_EIGHT_BIT &
            USART_CONT_RX &
            USART_BRGH_HIGH &
            USART_ADDEN_OFF ,
            52);
    for(int x=0;x<=20;x++){__delay_ms(50);}
    // write/send intro to PC
    while(BusyUSART());
    putsUSART((char *)txt1);
    for(int x=0;x<20;x++){__delay_ms(50);}
    while(BusyUSART());
    putsUSART((char *)txt2);
    while(1){
        sdata = ReadUSART();
        switch(sdata){
            case '1':
                LATBbits.LATB4 = 1;
                LATBbits.LATB1 = 0;
                LATBbits.LATB0 = 0;
            break;
            case '2':
                LATBbits.LATB4 = 0;
                LATBbits.LATB1 = 1;
                LATBbits.LATB0 = 0;
            break;
            case '3':
                LATBbits.LATB4 = 0;
                LATBbits.LATB1 = 0;
                LATBbits.LATB0 = 1;
            break;
            default:
                LATBbits.LATB4 = 0;
                LATBbits.LATB1 = 0;
                LATBbits.LATB0 = 0;
            break;
VERSION (II) ---------------------------
#include "fuses.h"
#include <stdio.h>
#include <stdlib.h>
#define STRLEN 12
volatile unsigned char t;
volatile unsigned char rcindex;
volatile unsigned char rcbuf[STRLEN];
void USART_init(void){
    TXSTAbits.TXEN = 1;     // enable transmitter
    TXSTAbits.BRGH = 1;     // high baud rate mode
    RCSTAbits.CREN = 1;     // enable continous receiving
    // configure I/O pins
    TRISCbits.TRISC7 = 1;     // RX pin is input
    TRISCbits.TRISC6 = 1;     // TX pin is input (automatically configured)
    SPBRG = 52;
    PIE1bits.RCIE = 1;      // enable USART receive interrupt
    RCSTAbits.SPEN = 1;     // enable USART
void USART_putc(unsigned char c)
    while (!TXSTAbits.TRMT); // wait until transmit shift register is empty
    TXREG = c;               // write character to TXREG and start transmission
void USART_puts(unsigned char *s)
    while (*s)
        USART_putc(*s);     // send character pointed to by s
        s++;                // increase pointer location to the next character
void main(void) {
    USART_init();
    USART_puts("Init complete! \n");
    INTCONbits.PEIE = 1;    // enable peripheral interrupts
    INTCONbits.GIE = 1;     // enable interrupts
    while(1)
void interrupt ISR(void)
    if (PIR1bits.RCIF)  // check if receive interrupt has fired
        t = RCREG;      // read received character to buffer
        // check if received character is not new line character
        // and that maximum string length has not been reached
        if ( (t != '\n') && (rcindex < STRLEN) )
            rcbuf[rcindex] = t; // append received character to string
            rcindex++;          // increment string index
        else
            rcindex = 0;        // reset string index
            USART_puts(rcbuf);  // echo received string
        PIR1bits.RCIF = 0;      // reset receive interrupt flag
Any and all help is appreciated. Thanks!
newbie14
newbie14
4 years ago
here are images of my hardware
