PIC24 programming troubles?
Hi,
I have been working on a board with a PIC24FJ32GA002. The board had the correct voltages on the PIC's power pins (3V). I was able to program the pic one time successfully with my PICkit3, but every subsequent attempt has resulted in the following error message:
Connecting to MPLAB PICkit 3...
Firmware Suite Version.....01.29.33
Firmware type..............dsPIC33F/24F/24H
Target detected
Device ID Revision = 3046
The following memory area(s) will be programmed:
program memory: start address = 0x0, end address = 0x2bff
Programming...
EEData memory
Address: 0 Expected Value: 0 Received Value: 0
Calibration memory
Failed to program device
I don't think the chip is fried since it still reads the device ID, but I have no idea what's going on with the EEData error. If anyone knows anything about this, that would be greatly appreciated. Thanks in advanced.
4 years ago
Try erasing the pic first.
Answer 4 years ago
Thanks. That seemed to work on the MPLAB IPE. Is there a reason the erase in the normal programming procedure in the MPLAB IDE is different from that on the IPE?
Answer 4 years ago
No idea how things running on windows do anything these days.......
Glad you can reuse the chip. I used to burn and reburn picks a good deal.
Most of the software would automatically erase a chip before burning a program in.
My problem was to disable the auto erase and let me reburn the program over 30 times which interestingly would allow a 5V chip those days to run reliably as low as 2.8Volts.
I like your radiation detection work
"I chose to base the probe around the R1307 photomultiplier tube, coupled to some scintillation plastic"
Any idea as to where to buy those items ?
My Geiger devices are fun but I could use better.
BTW you got a smart Dad....
Answer 4 years ago
I picked pretty much everything up on ebay. It's amazing what you can find there haha. I haven't upgraded my blog in a while, but I've made several more scintillators and a geiger counter with a pancake probe. I'm currently working on a gamma spectroscopy setup.
