434Views2Replies
PLEASE HELP, I'VE BUILT A HHO GENERATOR (2 CELLS-THE SPRING KIND)...how can i make the flame that comes from it bigger?
PLEASE HELP, I'VE BUILT A HHO GENERATOR (2 CELLS-THE SPRING KIND), I HOOKED THEM UP ON AN ADAPTER (12V), AND THEY MAKE JUST ENOUGH GAS FOR A LIIIIIIITTLE FLAME, AND EVEN THAT DOESN'T LAST LONG, SO I REALLY WOULD LIKE TO KNOW WHAT I CAN DO TO IMPROVE MY CELLS (HOW TO BOULD UP MORE PREASURE OR SOMETHING TO MAKE THE FLAME BIGGER) P.S. WHAT SHOULD I PUT IN THE WATER (I USE SALT OR BAKING SODA) AND AT WHAT RATIO THANKS FOR YOUR HELP
11 years ago
You need to collect the gas with a small compressor and store it in a tank. The compressor needs to cycle on and off for very short periods. The storage tank acumulates gas to pressure. The tank is like a battery with a charger attached. You need to charge the tank first. Then you can make a variable flame.
11 years ago
Measure your voltage and if it's lower than 12 volts you need more amps, otherwise you need more voltage and more amps. Larger adapter. Maybe a car battery booster charger would work best. Be careful because if it works too well it might explode. I have not seen a picture of what you made so I don't know how dangerous it is. Baking soda sounds safer because salt probably releases chlorine in it.
