751Views4Replies
Author Options:
PWM control and "off" for arduino IR remote? Answered
I've built a simple IR remote to trigger a led bar using...
https://www.instructables.com/id/Control-your-Arduino-with-a-remote/step5/Control-stuff/
As my template.
All the leds turn on a-okay but I'd like to be able to implement both an "off" function using the same button
ie. button1=High
leave on for desired period of time...
button1=Low
I'd like to be able to use a no delay fade in/out as well...
ie. button7= All leds fade in/out until button7=low (using the method above^^)
I've tried plugging in various other parts of code to no avail...
Any help would be greatly appreciated!!!
Thanks!
mpilchfamily
mpilchfamily
7 years ago
What code are you using and what changes have you made?
vtrguy
vtrguy
Answer 7 years ago
I've just discovered that using the code with the ON/OFF, if I get a repeat code..
4294967295
It will freeze and not accept any more transmissions. Is there anyway to get rid of that as well?
vtrguy
vtrguy
Answer 7 years ago
void loop() {
if ((irrecv.decode(&results)) && (results.value==16753245) ) {
if (state == 0) {
state = 1;
digitalWrite(LED, HIGH);
Serial.println("Center - HIGH");
} else {
state = 0;
digitalWrite(LED, LOW);
Serial.println("Center - LOW");
delay(50);
irrecv.resume();
I found this and I've gotten the on/off working, but am still having troubles with adding the fade
vtrguy
vtrguy
7 years ago
As well, I'm fairly new at this so please forgive me!
