8247Views23Replies
Author Options:
Passive subwoofer and receiver with "subwoofer pre out" plug in harman kardon avr 142 Answered
hello,
I have Harman kardon avr 142 with subwoofer pre out plug in (suitable for active sub), and passive pioneer subwoofer with two cords.
Between them I have rg59 with rca head (sub cable).
Is there a way some how to convert the pioneer sub to an active sub with rca plug in?
ThirdEarthDesign
ThirdEarthDesign
4 years ago
If you have a passive subwoofer but your AV-Receiver only supports an active sub you have two choices:
a) replace the passive subwoofer with an active one
b) use a LFE amp between the RCA pre out and and the passive sub
Unless the passive sub you currently have is of a particularly good quality, you might find option a) is your better option, if going for option b) you'll want to make sure the amp you use is intended for low-frequency
okozay
okozay
11 months ago
The only other connection option is that is available for a passive
subwoofer is that if the passive subwoofer has in and out standard
speaker connections, you can connect the left and right speaker
connections on a receiver or amplifier to the passive subwoofer and then
connect the left and right speaker output connections on the passive
subwoofer to your main left and right front speakers.
In this type of setup, the subwoofer will "strip off" the low
frequencies utilizing an internal crossover, sending the mid-range and
high frequencies to the additional speakers connected to the subwoofer's
speaker outputs. This eliminates the need for an extra external
amplifier for the passive subwoofer but may put more strain on your
receiver or amplifier because of the demands for low-frequency sound
output.
BarD2
BarD2
4 years ago
What lfe amp would you recommend? that will suit the pioneer sdv111 sub woofer ?(I added pictures of the sub)
I prefer low cost LFE amp that can make the job done with this low cost subwoofer...
ThirdEarthDesign
ThirdEarthDesign
Answer 4 years ago
It's difficult to pick out a recommended amp as the cost and specification can vary. According to the Pioneer manual (http://www.pioneer-latin.com/downloads/operating%...) the DV111 used a 60w amp with 8Ω impedance for the sub channel, so you will want something that comes close to this power output. Also you only require a single channel audio output, but you'll find that a lot of the amps will offer 2-3 channels, if this is the case you'll only wire up one of them.
BarD2
BarD2
Answer 4 years ago
The thing is most of the plate amp I find, are above $100, way beyond what I need for this sub.
ThirdEarthDesign
ThirdEarthDesign
Answer 4 years ago
Cost will be a factor, which is why I think replacing the sub may be the best solution. However you will find small amps for around $10, but I've never used anything like that before so can't comment on how good they might be.
BarD2
BarD2
Answer 4 years ago
I think with $10 I can take a risk, where can I find them?
BarD2
BarD2
Answer 4 years ago
Thanks fo the links!
Where to I plug my rg59 sub cable with rca head in the TPA3116D2 board? I think i see only the black 12-24v socket but no rca one...
And can I wire the inner subwoofer two cable cords to any of the 3 channels I want? will it work with 60w?
ThirdEarthDesign
ThirdEarthDesign
Answer 4 years ago
You'll either need to find one with an RCA input, use a RCA to 3.55mm jack adapter/cable or modify the board to include an RCA socket.
As I've said before, replacing the sub will be your simplest option, it may even turn out to be the cheapest one, especially once you factor in the time spent fiddling around trying to make things work.
As my father always says to me, buy cheap buy twice!
BarD2
BarD2
Answer 4 years ago
Is this board fine?
http://www.ebay.com/itm/TDA2030A-2-1-Stereo-Audio-Amplifier-3-Channel-Subwoofer-Amplifier-Board-HOT-/201572676641?hash=item2eeeaaf421:g:TS8AAOSw2GlXJGTs
it has two rca inputs, so if i plug the subwoofer cable with rca head to one of the board rca inputs, will it work?
ThirdEarthDesign
ThirdEarthDesign
Answer 4 years ago
Looks good to me, see no reason why it won't work. Probably worth a try :)
BarD2
BarD2
Answer 4 years ago
what kind of power supply do I need?
ThirdEarthDesign
ThirdEarthDesign
Answer 4 years ago
According to the specs of the amp you need a power supply that delivers Dual AC at 12v @ 60w (i.e. it has TWO positive (+) capable of 30w each and one negative/ground (-) ground terminals). I'm guessing it's using dual power to supply L and R channels independently. The use of AC is a little surprising as most domestic applicances and circuits would use DC, but I'm no electrical expert so can't comment too much on this.
BarD2
BarD2
Answer 4 years ago
Is there link for this sort of power supply on ebay?
ThirdEarthDesign
ThirdEarthDesign
Answer 4 years ago
That one doesn't output 12v, only 5v and 24v. You want one that dual outputs 12v.
As you are only using one channel of your amp maybe it only needs one of
the power inputs to be live, but I really don't know. Also you may be
able to use a single power output and just run it in parallel with the
two inputs on the amp, but again I don't know if that will work either.
With the cost of the amp, power supply, and the time spent fiddling around
(with no guarantees that you will be happy with the end result), opting
for a new (or second hand) active sub might be the best way forward
here, I would really consider it if I were you.
BarD2
BarD2
Answer 4 years ago
Thanks
BarD2
BarD2
Answer 4 years ago
Is this right?
http://www.ebay.com/itm/12V-5A-60W-AC-to-DC-Switch-Power-Supply-Transformer-for-LED-Strip-light-CCTV-/320916632161?hash=item4ab81f3261:m:maMdWeIKiXs9dtvDwW0h4mA
ThirdEarthDesign
ThirdEarthDesign
Answer 4 years ago
Hi, that one is no good as it outputs DC, you need one that outputs AC for the amp you've chosen.
You want something like this one, it has dual AC output but it requires a separate DC power supply, but the wattage is pretty low on this one (5w apparently).
http://www.ebay.com/itm/DC-to-Dual-AC-12V-Power-Su...
BarD2
BarD2
Answer 4 years ago
So if I understand right, this is the kind of PSU I need? (only with 12v)
http://www.ebay.com/itm/RD-65B-Mean-Well-Power-Supply-Dual-Output-/122011246023?hash=item1c686fddc7:g:CFQAAOSwtJZXWhjw
rickharris
rickharris
4 years ago
Depends on the power output you need/expect but Amazon and ebay are awash with neat ready made amplifiers you could put inside the speaker enclosure and get what you want.
