1530Views4Replies
Petty Coin Bank Design - Coin Dispenser. What should i use?
Hey Guys, need your advise on this...
Going straight ahead to the point, What can you suggest i can use for the movement of the Plate in the Coin Dispenser Design in the image?
I need a component that does a push-pull action based on the design inspired from this video:
http://www.youtube.com/watch?v=rwG-sG27360
Need your advise. :)
2 years ago
Hello
What I would Suggest is a stepper motor with a linear rack if you're looking to make it fully automatic.
Regards
C
8 years ago
Or you could attach the sliding tray to a selenoid and push/pull it that way.
8 years ago
Nice drawings!
OR you can use a rotary system with a slow running geared motor. See diagram
The disc has a coin sized hole in it and rotates under the coin tube. The bottom plate stops the coins falling right through. As the disc sweeps round it collects a coin and then sweeps it off the bottom plate into the delivery chute.
8 years ago
Locomotive linkage: Turn the wheel, a link from the wheel to the plate will slide the plate forward and back as the wheel turns.
