104Views1Replies
Author Options:
Please help a noob Answered
I have a script that kills processes listed in text file, i need it to also run listed processes if they are closed.
@echo off
echo Edvinas Petukas Mtnl_14
@echo off &setlocal enabledelayedexpansion
tasklist /fo list|find /i ".exe">%temp%\running.tmp
for /f "tokens=2*" %%a in (%temp%\running.tmp) do (
call :process %%b
pause
exit /b
:process
for /f "tokens=*" %%c in (sarasas.txt) do if "%*"=="%%c" (
set Answ=N
echo Isjungti procesa?
set /p Answ=Kill %*?
IF /I NOT "!Answ!"=="Y" GOTO :EOF
if errorlevel 1 goto :EOF
echo Killing %%c
taskkill /f /im "%%c"
Tags:DOS
g-one
g-one
6 years ago
The following code will crate the file "veikiaproc.txt" with only the already running processes.
Your list in "sarasas.txt" shall contain the programs that you want to run. If the programs can be found in the %path% environment or they are registered in
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths
it would be sufficient to have only the program name in the list, e.g.
cmd.exe
Otherwise you have to write the entire path, e.g.
C:\foo\bar.exe
:: ~~~~~~~ code ~~~~~~~~~
@echo off &setlocal DisableDelayedExpansion
>"veikiaproc.txt" (for /f delims^=^" %%i in ('tasklist /nh /fo csv') do echo %%i)
for /f "usebackq delims=" %%i in ("sarasas.txt") do (
>nul findstr /ixc:"%%~nxi" "veikiaproc.txt" && (
echo running %%i
echo NOT running %%i
start "" "%%i"
del "veikiaproc.txt"
pause
