941Views1Replies
Author Options:
Please help me solve this error in code Answered
Arduino: 1.8.5 (Windows 8.1), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\libraries\NewSoftSerial-master\NewSoftSerial.cpp:39:24: fatal error: WConstants.h: No such file or directory
#include "WConstants.h"
compilation terminated.
exit status 1 Error compiling for board Arduino/Genuino Uno.
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
/* JPEG Camera Example Sketch The sketch will take a picture on the JPEG Serial Camera and store the jpeg to an SD card on an SD Shield Written by Ryan Owens SparkFun Electronics
Hardware Notes: This sketch assumes the arduino has the microSD shield from SparkFun attached. The camera Rx/Tx should be attached to pins 2 and 3. IMPORTANT: The JPEG camera requires a TTL level shifter between the camera output and the arduino. Bypassing this may damage the Arduino pins. *
/This example requires the MemoryCard, SdFat, JPEGCamera and NewSoftSerial libraries #include #include #include #include #if defined(ARDUINO) && ARDUINO >= 100 #include "Arduino.h" #else #include "WProgram.h" #endif #include
//Create an instance of the camera JPEGCamera camera;
//Create a character array to store the cameras response to commands char response[32]; //Count is used to store the number of characters in the response string. unsigned int count=0; //Size will be set to the size of the jpeg image. int size=0; //This will keep track of the data address being read from the camera int address=0; //eof is a flag for the sketch to determine when the end of a file is detected //while reading the file data from the camera. int eof=0;
void setup() { //Setup the camera, serial port and memory card camera.begin(); Serial.begin(9600); MemoryCard.begin(); //Reset the camera count=camera.reset(response); delay(3000); //Take a picture count=camera.takePicture(response); //Print the response to the 'TAKE_PICTURE' command. Serial.write((const uint8_t*)response, count); Serial.println(); //Get the size of the picture count = camera.getSize(response, &size); //Print the size Serial.print("Size: "); Serial.println(size); //Create a file called 'test.txt' on the SD card. //NOTE: The memoryCard libary can only create text files. //The file has to be renamed to .jpg when copied to a computer. MemoryCard.open("/test.txt", true); //Starting at address 0, keep reading data until we've read 'size' data. while(address < size) { //Read the data starting at the current address. count=camera.readData(response, address); //Store all of the data that we read to the SD card for(int i=0; i
void loop() {
