87Views7Replies
Please help to select a power source for 100W LED?
I want to make a spotlight using 100W LED powered by a 2200mAh LiPo. I understand I need a power booster for this. Please suggest one of the correct specification.
The LED: http://www.ebay.in/itm/100W-LED-COB-Chip-CW-WW-Blue-Red-Green-Super-Bright-single-color-/331632451175?var=&hash=item4d36d59e67:m:mxsTE0PLt5bDCjp8vJJs5CQ
The battery: Standard LiPo of 11.2V. max current of 55A
Thanks a lot
5 years ago
http://www.ebay.com/itm/100W-DC-DC-Boost-Power-Converter-LED-Driver-Constant-Current-Voltage-12V-24V-CAR-/281764885584?hash=item419a7ef450:g:L7gAAOSwHnFVv8Ls
Answer 5 years ago
+0.99
That Definitely what your looking for,
But the Spec's for that say that the output current is 0.5 - 5Amp.
If the Led is using 32-36V (on the upper end of what the device can supply) then it will most likely provide less then the 5Amp max.
You think it could do the 3Amp the Led needs?
Btw I saw this of the right side of the screen,
https://www.instructables.com/id/homemade-100W-LED-flashlight/
Answer 5 years ago
His MMV...
The 100W flashlight lacks any current control.
Answer 5 years ago
Yeah I noticed that too! See a bit odd eh?
Mainly posted that link for the other components like the heat-sink and lens
Looks like he compensated by keeping the voltage lower, 30V instead of 35. Should be right in the range were the lowed Voltage mean the device isn't pulling more current. Kinda like those cheep key-chain flashlights.
Answer 5 years ago
Perhaps as well, if that LED turns on fully, it will make quite a bang without a limit....
5 years ago
What's the maximum discharge current from your battery ?
Answer 5 years ago
55A
