99Views5Replies
Plot a diagonal line?
PD17200,11600;
i am sure I should know this.
I need to plot a diagonal line from 17200 to 11600 Obviously there are more X points than Y points.
Is there a handy algorithm to work out how may X points to ploy against Y?
My current solution is to extract the difference - 5600 and divide the Y by that 11600/5600 = 2.1
So you plot 2.1 Y points for every X point. Somehow this seems wrong?
Best Answer 5 years ago
Look at "Bressenhams line drawing algorithm"
5 years ago
Thanks for the answers guys, Let me amplify a little more just to satisfy everyone.
I have a CAD program that can output in HPGL. I want to see if I can translate the HPGL into x,y movement for a plotter/cutter using a PIC micro.
Ill use the information you have given me thanks.
Steve, have seen Bressenhams algorithm before and should have remembered - Thanks.
Jack, thanks for the maths reminder - I knew I should have known it.
Answer 5 years ago
You can do Bressenham's with only integer maths too.
Answer 5 years ago
So I see on reading it up. Now to try to convert it to some code. thanks.
5 years ago
Your question does not make sense to me. I am guessing you want to draw a line in the xy plane.
Points in the xy plane are defined by pairs of two numbers. One of these numbers is the x part. The other is the y part.
For example (x1,y1) is a point in the xy plane.
Also (x2, y2) is a point in the xy plane.
The usual formula for a line, in the xy plane, is:
y = m*x + b
Suppose, I want to know the formula for a line which includes the two points I mentioned earlier, (x1,y1) and (x2, y2).
Both satisfy the formula for a line.
y1 = m*x1 + b
y2 = m*x2 + b
All that remains is to solve for m and b.
m = (y2-y1)/(x2-x1)
b = y1 - m*x1 = y2 - m*x2
Once you have an equation for your line, plotting the line should be easy.
