Pls help me with my code
I want to make home automation project using arduino. I want to control multiple led, password protected door and temperature showing. I have 3 code for these 3 feature. But I want to combine them together to control it from 1 android device. i just want to make work like that- if i press "Q" command then it will show temperature. if i press "R" command then it will work like multiple led controller. if i press "S" command then it will work like password protected locker.
This is the code for bluetooth led control:-
int relay1 = A0;<br> int relay2 = A1; int relay3 = A2; int relay4 = A3; String readString; void setup() { Serial.begin(9600); pinMode(relay1, OUTPUT); pinMode(relay2, OUTPUT); pinMode(relay3, OUTPUT); pinMode(relay4, OUTPUT); } void loop() { while (Serial.available()) { delay(3); char c = Serial.read(); readString += c; } if (readString.length() >0) { if (readString == "A") { digitalWrite(relay1, HIGH); Serial.print("Relay 1 is On"); } if (readString == "W") { digitalWrite(relay1, LOW); Serial.print("Relay 1 is Off"); } //relay2 if (readString == "B") { digitalWrite(relay2, HIGH); Serial.print("Relay 2 is On"); } if (readString == "X") { digitalWrite(relay2, LOW); Serial.print("Relay 2 is Off"); } //relay3 if (readString == "C") { digitalWrite(relay3, HIGH); Serial.print("Relay 3 is On"); } if (readString == "Y") { digitalWrite(relay3, LOW); Serial.print("Relay 3 is Off"); } //relay4 if (readString == "D") { digitalWrite(relay4, HIGH); Serial.print("Relay 4 is On"); } if (readString == "Z") { digitalWrite(relay4, LOW); Serial.print("Relay 4 is Off"); } //All on / off if (readString == "E") { digitalWrite(relay1, HIGH); digitalWrite(relay2, HIGH); digitalWrite(relay3, HIGH); digitalWrite(relay4, HIGH); Serial.print("All Relay Is On"); } if (readString == "F") { digitalWrite(relay1, LOW); digitalWrite(relay2, LOW); digitalWrite(relay3, LOW); digitalWrite(relay4, LOW); Serial.print("All Relay Is Off"); } //next readString=""; } }
This is the code for password control door:
String inputString = "";<br> String command = ""; String value = ""; String password = "test123"; //setpassword here boolean stringComplete = false; int relay = 2; int greenLed = 5; int redLed = 6; void setup(){ Serial.begin(9600); // make sure it is the same baudrate as your bluetooth module inputString.reserve(50); command.reserve(50); value.reserve(50); boolean stringOK = false; pinMode(relay, OUTPUT); digitalWrite(relay, HIGH); pinMode(greenLed, OUTPUT); pinMode(redLed, OUTPUT); digitalWrite(redLed, HIGH); } void loop(){ if (stringComplete) { delay(100); int pos = inputString.indexOf('='); if (pos > -1) { command = inputString.substring(0, pos); value = inputString.substring(pos+1, inputString.length()-1); // extract command up to \n exluded if(!password.compareTo(value) && (command == "OPEN")){ openDoor(); Serial.println(" OPEN"); delay(100); } else if(!password.compareTo(value) && (command == "CLOSE")){ closeDoor(); Serial.println(" CLOSE"); delay(100); } else if(password.compareTo(value)){ Serial.println(" WRONG"); delay(100); } } inputString = ""; stringComplete = false; } } void serialEvent() { while (Serial.available()) { char inChar = (char)Serial.read(); //Serial.write(inChar); inputString += inChar; if (inChar == '\n' || inChar == '\r') { stringComplete = true; } } } void openDoor(){ digitalWrite(relay, LOW); digitalWrite(redLed, LOW); digitalWrite(greenLed, HIGH); } void closeDoor(){ digitalWrite(relay, HIGH); digitalWrite(redLed, HIGH); digitalWrite(greenLed, LOW); }
This is the code for temperature showing:
int data_pin = 9;<br> int vcc_pin=8; int gnd_pin=10; boolean result[41]; //holds the result int interval=2000; //Sample every 2 seconds unsigned int temp; //in celcius unsigned int humidity; //in %RH void setup() { //Supply power to DHT11 (Uses upto 2.5mA) pinMode(gnd_pin, OUTPUT); pinMode(vcc_pin, OUTPUT); digitalWrite(gnd_pin,LOW); digitalWrite(vcc_pin,HIGH); //Initiate Serial for Bluetooth Communication Serial.begin(9600); } void loop() { //Pause before taking next measurement delay(interval); //Trigger reading by holding data pin low for 18ms pinMode(data_pin, OUTPUT); digitalWrite(data_pin,LOW); delay(18); digitalWrite(data_pin,HIGH); pinMode(data_pin, INPUT_PULLUP); //read 41 bits of signal for(int i=0;i<=40;i++){ result[i]=(pulseIn(data_pin, HIGH)>40); } //Extract Humidity (from byte 1) humidity=0; for (int i=1;i<=8;i++){ humidity=humidity<<1; if (result[i]) humidity|=1; } //Extract Temperature (from Byte 3) temp=0; for (int i=17;i<=24;i++){ temp=temp<<1; if (result[i]) temp|=1; } //Send data over Bluetooth Serial.print("*T"+String(temp)+"*"); Serial.print("*H"+String(humidity)+"*"); }
This is the code i tried to combine all together.i just want to make work like that- if i press "Q" command then it will show temperature. if i press "R" command then it will work like multiple led controller. if i press "S" command then it will work like password protected locker.I tried `if(readString == "Q")` , `if(readString == "R")` , `if(readString == "S")` for control the code seperately but its not working:
int data_pin = 9;<br> int vcc_pin=8; int gnd_pin=10; int relay1 = A0; int relay2 = A1; int relay3 = A2; int relay4 = A3; int relay = 2; int greenLed = 5; int redLed = 6; boolean result[41]; //holds the result int interval=2000; //Sample every 2 seconds unsigned int temp; //in celcius unsigned int humidity; //in %RH String inputString = ""; String command = ""; String value = ""; String password = "test123"; //setpassword here boolean stringComplete = false; String readString; void setup() { //Supply power to DHT11 (Uses upto 2.5mA) pinMode(gnd_pin, OUTPUT); pinMode(vcc_pin, OUTPUT); digitalWrite(gnd_pin,LOW); digitalWrite(vcc_pin,HIGH); pinMode(relay1, OUTPUT); pinMode(relay2, OUTPUT); pinMode(relay3, OUTPUT); pinMode(relay4, OUTPUT); pinMode(relay, OUTPUT); digitalWrite(relay, HIGH); pinMode(greenLed, OUTPUT); pinMode(redLed, OUTPUT); digitalWrite(redLed, HIGH); inputString.reserve(50); command.reserve(50); value.reserve(50); boolean stringOK = false; //Initiate Serial for Bluetooth Communication Serial.begin(9600); } void loop(){ if (readString == "Q"){ //Pause before taking next measurement delay(interval); //Trigger reading by holding data pin low for 18ms pinMode(data_pin, OUTPUT); digitalWrite(data_pin,LOW); delay(18); digitalWrite(data_pin,HIGH); pinMode(data_pin, INPUT_PULLUP); //read 41 bits of signal for(int i=0;i<=40;i++){ result[i]=(pulseIn(data_pin, HIGH)>40); } //Extract Humidity (from byte 1) humidity=0; for (int i=1;i<=8;i++){ humidity=humidity<<1; if (result[i]) humidity|=1; } //Extract Temperature (from Byte 3) temp=0; for (int i=17;i<=24;i++){ temp=temp<<1; if (result[i]) temp|=1; } //Send data over Bluetooth Serial.print("*T"+String(temp)+"*"); Serial.print("*H"+String(humidity)+"*"); } if (readString == "R"){ while (Serial.available()) { delay(3); char c = Serial.read(); readString += c; } if (readString.length() >0) { if (readString == "A") { digitalWrite(relay1, HIGH); Serial.print("Relay 1 is On"); } if (readString == "W") { digitalWrite(relay1, LOW); Serial.print("Relay 1 is Off"); } //relay2 if (readString == "B") { digitalWrite(relay2, HIGH); Serial.print("Relay 2 is On"); } if (readString == "X") { digitalWrite(relay2, LOW); Serial.print("Relay 2 is Off"); } //relay3 if (readString == "C") { digitalWrite(relay3, HIGH); Serial.print("Relay 3 is On"); } if (readString == "Y") { digitalWrite(relay3, LOW); Serial.print("Relay 3 is Off"); } //relay4 if (readString == "D") { digitalWrite(relay4, HIGH); Serial.print("Relay 4 is On"); } if (readString == "Z") { digitalWrite(relay4, LOW); Serial.print("Relay 4 is Off"); } //All on / off if (readString == "E") { digitalWrite(relay1, HIGH); digitalWrite(relay2, HIGH); digitalWrite(relay3, HIGH); digitalWrite(relay4, HIGH); Serial.print("All Relay Is On"); } if (readString == "F") { digitalWrite(relay1, LOW); digitalWrite(relay2, LOW); digitalWrite(relay3, LOW); digitalWrite(relay4, LOW); Serial.print("All Relay Is Off"); } //next readString=""; } } if (readString == "S"){ if (stringComplete) { delay(100); int pos = inputString.indexOf('='); if (pos > -1) { command = inputString.substring(0, pos); value = inputString.substring(pos+1, inputString.length()-1); // extract command up to \n exluded if(!password.compareTo(value) && (command == "OPEN")){ openDoor(); Serial.println(" OPEN"); delay(100); } else if(!password.compareTo(value) && (command == "CLOSE")){ closeDoor(); Serial.println(" CLOSE"); delay(100); } else if(password.compareTo(value)){ Serial.println(" WRONG"); delay(100); } } inputString = ""; stringComplete = false; } } } void serialEvent() { while (Serial.available()) { char inChar = (char)Serial.read(); //Serial.write(inChar); inputString += inChar; if (inChar == '\n' || inChar == '\r') { stringComplete = true; } } } void openDoor(){ digitalWrite(relay, LOW); digitalWrite(redLed, LOW); digitalWrite(greenLed, HIGH); } void closeDoor(){ digitalWrite(relay, HIGH); digitalWrite(redLed, HIGH); digitalWrite(greenLed, LOW); }
