38Views1Replies
Author Options:
Portable media build parts question Answered
I'm looking to build a portable gaming and media station but I'm stuck on a couple things and am hoping people here might have some suggestions and/or links. Basically, I bought a large aluminum camera case, big enough to hold a 22" led tv in the lid. I am going to mount the tv in the lid, thinking of just drilling the holes and mounting the tv directly to the lid. Any critiques or problems with that would be nice.
Second, I'm going to mount a ps3, a portable media player (think Von Haus) which uses flash drives or portable hard drive via US, and a retropie system. Now where I'm running into trouble is two-fold. One is how to mount the items into the case. Foam would normally work well, but I'm worried about heat reduction, less so for the media player and more for the ps3 and retropie. I'm also worried about having it hardmounted onto the case via glue gun because of any shocks it might get while in transport. I also want to dremel out in the front and the back, and put in ports to be able to connect to an outside source as needed. Basically, I need a number of connectors which mount inside with the port leading out. USB 2/3, HDMI, RCA cable connector (RWY). I can find extension cables, but what I'm more looking for is, say for USB, a male lead on one end to connect to the ps3, and a female lead on the other end which sits inside case but is dremel'ed out to be able to connect a USB from the outside, basically a plate which I can just screw in. Something similar to what you'd find inside a console or similar. Anything which anyone can help with on any of these would be greatly appreciated.
Downunder35m
Downunder35m
1 year ago
For the screen:
You will need to make suitable brackets on the metal frame of the TV.
That is the part INSIDE the plastic frame.
Sometimes you are lucky and use the holes for some mounts of the plastic housing if they go through holes in the frame.
For the rest:
Consider to make seperate housings for all devices with a small cooling fan.
Some foam strips on the sides could then keep the devices secured in their housing.
The housings itself you can fix to the box as all is removable now.
Add a cover behing the TV with vent holes on one side and a fan on the other side, preferably blowing the air right out the box.
With that you will be able to remove and heat inside, just include suffient venting for the housings and devices inside so outside air will be sucked in around them.
