88Views7Replies
Author Options:
Possible replacement PSU for PC? Answered
I am fixing a PC for someone and I believe the power supply is dead. I have been looking for a replacement but can't find one exactly the same. It is also from a 'slim' model PC so the psu is smaller than normal. Here are the specs of the original:
Input=100-127v ~6A, Output=220W, +3.3v=13A, +5v=14v, +12v=14A, +5VSB=2A, -12v=0.3A. I was wondering if this one on ebay could replace it. Do the Amps and wattage need to be exactly like the original?
steveastrouk
steveastrouk
Best Answer 6 years ago
It should be fine. Don't choose a supply with a LOWER power rating than the one you're replacing.
Arya42
Arya42
Answer 6 years ago
I found a psu that is 250w, and all of the amp ratings are sightly higher than the original. The only difference is in the input rating, which is 110-240v~5A, where the original was 100-127v~6A. Coeld this cause a problem? Sorry for all the questions, but I am new to this so I want to learn what to look for on computer hardware.
steveastrouk
steveastrouk
Answer 6 years ago
That will be fine. Its just a more efficient supply than the one you chose before
Arya42
Arya42
Answer 6 years ago
Oops, didn't notice it was missing the SATA cable. I found a new one that is 250w but the amps for +3.3v and +5v are a little (one value) lower than the original. Is this bad?
steveastrouk
steveastrouk
Answer 6 years ago
Get a SATA extender...but it probably won't matter anyway
Vyger
Vyger
6 years ago
Often with those power supplies the fans go bad because they have cheap bearings then with no cooling the unit burns up. Check for a MTBF number (Mean time between failure) in hours if they have a higher hours number that usually means they have better fans. It might cost a little more but it will last a lot longer. So it probably didn't fail because of not having enough capacity but more likely because of not having enough cooling or the other big killer of Power supplies, voltage surges.
Arya42
Arya42
6 years ago
Thanks for your quick reply. I think I will get one with more wattage as this particular pc model is known for having dead power supplies. Just one more question: if the original had +5v at 14A and a new one had +5v at 12A, would this be too low? Should the amps rating be the same or higher on a new psu?
steveastrouk
steveastrouk
Answer 6 years ago
I would think it would "probably" work with a 12A supply. Ideally the new PSU would have equal or greater current capacity
