215Views3Replies
Author Options:
Power Suppy Answered
I need to make a 6.5 vdc - 500ma power supply I have no clue how to make it 6.5v. any help is deeply appreciated
steveastrouk
steveastrouk
Best Answer 9 years ago
Assuming you HAVE a DC supply with an output of more than about 8V, and capable of delivering 500mA (so you're looking for 8V @ >4 watts, then you just need an LM317 voltage regulator and two resistors.
Here's a link with not only the circuit, but the resistor values for you.
http://www.electronicspoint.com/power-supply-t232944.html
Steve
verence
verence
9 years ago
Is your supply from batteries or from a wall wart?
What is the input voltage?
Do you need exactly 6.5V or just about 6.5V?
If you can live with the losses of a linear regulator:
- Will 5V do? Use a 7805.
- Will 6V do? Use a 7806 if you can find one.
- You need just about 6.5V? Lift the ground pin of a 7805 with two diodes (1N4001 or similar) - that should give about 6.2..6.3V
- You need most exactly 6.5V? Use a LM317 adjustable regulator or something similar.
Kiteman
Kiteman
9 years ago
You need to define the input current and voltage.
