418Views5Replies
Author Options:
Power on top of spinning wheel? Answered
I have a spinning wheel powered by a 12v motor and i want to run some lights on top of the wheel without putting on a 2nd battery or having the wires get tangled up
mpilchfamily
mpilchfamily
Best Answer 5 years ago
Spinning wheel? As in spinning your own yarn? So Lights attached to the side of the wheel to put on a show as it spins. Best thing to do would be to attach some LED throwies to it. LED Thowies are just a basic LED taped onto a 3V coin cell battery. No wires and no fuss. Otherwise you have to run wires from your 12V battery up to a pair of copper brushes. One for the negative side and one for the posative side. Then you would need 2 copper rings on the wheel that the brushes make contact with. Run your wire from those rings to the lights and your all done.
FarmerKJS
FarmerKJS
Answer 5 years ago
Thanks i was going to use the rings and brush idea but i didnt thing it would work to well
iceng
iceng
5 years ago
Two ways, first use a simple slip ring and the shaft as the LED power see the toy.
Second idea, an air coil to coil transformer ( make a neat ible )
Basically wind a 20 turn primary stationary coil around the spinner wired to a PWM driver and a secondary coil just above it spinning as close as feasible.
Whatever high frequency you can build to transfer energy gets rectified on your wheel and light up.
iceng
iceng
Answer 5 years ago
Sadly I'm going to have to make that ible once HQ decides on Pro rewards for featured ibles....
rickharris
rickharris
5 years ago
1 what is the question
2. Pictures would really help.
